Ricoh 5050 and 7000
cplari
Re: Ricoh 5050 and 7000
Post by cplari »
Just wondered if anyone has used the sawgrass powerdriver with the A4 ricoh 5050. We are using it with the A3 7000 and want to switch to the A4.
John G
Post by John G »
You cannot use the powerdriver on the 5050n, just the profile and the print as normal through coreldraw etc.
cplari
Post by cplari »
Is there any way to mirror the print from Acrobat reader, we are printing onto ceramics and need a mirrored image.
thanks
John G
Post by John G »
Not sure if acrobat reader is covered with the ink profiles - why are you using this to print with?
cplari
Post by cplari »
It's part of our automated software that calls up an order then prints a packing sheet on a laser printer and the dye sub artwork to the Ricoh. We use Acrobat reader to do this and the powerdriver has an option to mirror the print to the 7000, we have 2 5050 which we want to use as well but the powerdriver is not compatible. Just looking for a way to avoid having to buy another 7000 :)
Why not open the pdf in Photoshop and print from there? Will your automated package allow you to do that?
