BMS European Mug
Re: BMS European Mug
Post by GoonerGary »
I'm on the hunt for a back up mug. Can anyone tell me if the 10oz BMS European mugs are manufactured in India or Thailand? Do they require the base to be pre-heated when doing a full top to bottom print?
Tam
Post by Tam »
Don't know where they are made but I pre-heat them! I've not long started pressing and just had a customer say it cracked tonight after about 100 cups of tea. So not happy at the moment but I know these things happen!
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
I would expect it to crack with the first cuppa if it was flawed. After a 100 it's probably had a wack somewhere.
I dug out something a while back, and listed life expectancy of a mug as 50 uses.
Janners
Tam
Post by Tam »
Thanks for that Janners I don't feel as bad now!
Tam
James990
Post by James990 »
WOW only 50 mine must be really good then, it has had over 200 cups of coffee so far and still going strong!
JMugs
Post by JMugs »
My thoughts exactly, I have a mug which is used most days and is now 35 years old! Not sure how they worked it out.
galerion
Post by galerion »
RN are made in Thailand.
GoonerGary;118773 wrote:I'm on the hunt for a back up mug. Can anyone tell me if the 10oz BMS European mugs are manufactured in India or Thailand? Do they require the base to be pre-heated when doing a full top to bottom print?
This mug type is manufactured in Thailand.
Customprintwales
Post by Customprintwales »
50 uses!
The Duraglaze mugs are obviously over-engineered if they have been tested through 2000 dishwasher cycles.
I have mugs going strong that have been used over 2000 times. At my prices my customers would not be very happy if I gave them a life of just 50 uses.
Ali P
Post by Ali P »
GoonerGary;118773 wrote:... Do they require the base to be pre-heated when doing a full top to bottom print?
We use those and don't pre-heat.
