We've been using DyeTrans Hi-Res SublimationPaper for our hard substrates and TexPrintXP Sublimation Paper for our softsubstrates with our Epson stylus pro 7890's for a few years now.
However we just bought an Epson Surecolor F6200, so now I'm looking into what papers to use for that.
The dealer who sold us the F6200 is recommending the Epson Multipurpose Paper for both the hard and soft substrates. But I was just told that A. that paper is not very good and B. you never really want to use the same paper for both hard and soft substrates.
We mostly deal in high end photographic work so image quality is very important.
Does anyone have any good recommendations? I've heard that Sihl has some very good options but I'm not sure about which particular Sihl paper to use.
Thanks for any suggestions that you can give!!!!
Recommended sublimation paper for Epson F6200
Re: Recommended sublimation paper for Epson F6200
https://www.coldenhove.com/products/jetcol/
Subliprint premium is Sihl. I'm guessing the lighter papers may also be Sihl.
https://www.xpres.co.uk/search.aspx?search=subliprint
We did used to use Coldenhove JetCol High Speed, and definitely rate it as the best we've used. They have a range of papers for diferent uses, so you could use different papers for different substrates if you wanted to.
We now use InkTec's papers cause we can get them cheap, but if if wasn't for that, we'd be still on JetCol!
We run a couple of epsom sc-t 3200's, both use 24" Texprint XPhr rolls, 99% printing fabrics so we didn't want to swap about as it's ideal for that, but with a first class custom profile from our ink supplier (We use Sublinova ink) and slight timing adjustments we've found it works equally well on hard substrates too such as alloy tins, glass and ceramics.
Ricky@Xpres
Hello Forrest
We have a couple of options available https://www.xpres.co.uk/c-619-sublimati ... rolls.aspx
For fabric i would recommend our Subliprint Light 70gsm and for hard substrates TexPrint by Beaver or True Pix.
If you would like any samples please PM me your details.
Ricky
Xpres
Ricky
Xpres
Coldenhove papers are available from iSub
https://www.i-sub.co.uk/digital-textile ... sfer-paper
Users browsing this forum: Amazon [Bot] and 0 guests
