External Power Box -- Rotary Heat Press
angelbaby
Re: External Power Box -- Rotary Heat Press
Post by angelbaby »
I find there is external power box appear in a rotary heat press i am interested, it need extra $800 cost to do it.
Is it deserve to add this item?
(Link removed by admin)
They claim the advantage:
a) Protect main electric parts from high temp of the machine body during operating, so longer life cycle;
b) With individual voltage and current indicator;
c) Adjustable power based on jobs to save energy
galerion
Post by galerion »
I may not be the best person to offer advice on this as that's not a bit of kit I have any experience with, hopefully someone with more knowledge will come along and help you out from a experienced point of view.
If power supply heat is effecting the electric parts that is a pretty big design flaw and the thing that comes to mind is the original xbox 360 console (ring of red) where the heat generated inside it would warp the motherboard.
For a big bit of kit like that though if I were worried about the electric part I would probably invest in a uninterruptible power supply to go between it and the mains. These give you some time to shutdown properly in the event of a power cut and regulates the power which protect against micro surges.
The advert says it is optional ... what does it actually do?
logobear
Post by logobear »
Angelbaby - you a new member,
1st post, are you trying to promote your own equipment ?
It seems completely irrelevant to this forum,......
Angelbaby, please contact me via PM to confirm you are not a Spammer!
logobear;128517 wrote:Angelbaby - you a new member,
I'd have thought a heat press would be relevant to the forum?
galerion
Post by galerion »
Justin;128518 wrote:Angelbaby, please contact me via PM to confirm you are not a Spammer!
Interesting that a first post asking a question about a piece of equipment and linking to said equipment is triggering you to question if it is spam. I would think questions about equipment with links were fairly common for a first post, do we have some location based profiling going on here?
angelbaby
Post by angelbaby »
Thanks for your advice, but it is hard to use UPS as the power consumption is quite high & need 3 phases 380V.
You can see power consumption by this link
http://www.eastyltd.com/e_products/Mult ... s-p84.html
So that is why there is external power box as an option to move all those electronic part outside the main body to protect them from the high temp
angelbaby
Post by angelbaby »
Sorry for my late reply, it is not a spammer
angelbaby
Post by angelbaby »
Just ask if it is worth to add the external power box by paying extra US$800
