Chromaluxe sublimation help
bross1004
Re: Chromaluxe sublimation help
Post by bross1004 »
Having trouble with learning to sublimate onto chromaluxe 8x10 panels. I have tried twice and its not turning out. My printer is a Epson WF-7710 using DyeMaster-R 105gsm paper at 400 degrees (drops a few degrees upon press, but not much) with image face down and substrate face up per instruction. Tried both medium and high pressure when closing (or what i think is med/high pressure). I hover over the image for 10 seconds to ensure its dry and the second time I did a 45 second press on the substrate as well(online recommendation) to ensure it was ready to receive the image. I have included pictures of both of the ones I tried in hopes that someone else has made the same mistakes before and will recognize it. Any guidance is welcomed.
vB_ID:5450
vB_ID:5450
Picture 4.jpg (79.56 KiB) Viewed 228 times
vB_ID:5450
vB_ID:5450
vB_ID:5450
vB_ID:5450
vB_ID:5450
vB_ID:5450
vB_ID:5449
vB_ID:5449
Picture 3.jpg (94.93 KiB) Viewed 228 times
vB_ID:5448
vB_ID:5448
Picture 2.jpg (84.07 KiB) Viewed 228 times
vB_ID:5447
vB_ID:5447
Picture 1.jpg (94.97 KiB) Viewed 228 times
vB_ID:5446
vB_ID:5446
Picture 1.jpg (95.19 KiB) Viewed 228 times
I'm assuming you removed the clear plastic film from the sheets before pressing?
I use Sublimetals oanels and press with a VERY light pressure.
Could be too much temp causing the mottling. My metal I press at 160c for 70 secs, keeping the temp down helps. As with most products, you don't need much pressure as there's nowhere to push the image into :-) Good tip above to removed the plastic, we've all done it.
logobear
Post by logobear »
plastic film .....
bross1004
Post by bross1004 »
Yes, plastic sheeting was removed. So maybe too much pressure?
Cut a panel into small pieces to experiment with as it's usually a bit hit-and-miss at first.
I use only enough pressure to lock the press. Virtually just the weight of the top platen is enough.
bross1004
Post by bross1004 »
Good idea Webtrekker. I'll try that. Experimenting with full panels is expensive.
