Vinyl on Fleece?
Stitch Up
Re: Vinyl on Fleece?
Post by Stitch Up »
Hi all
As far as I'm aware there's no vinyl that can be used with fleece?
Is this still so?
John
I did it years ago, it works but crushes the pile. If you put a piece of fleece reversed over the top when pressing it helps but still not pretty.
Stitch Up
Post by Stitch Up »
Thanks Justin - hope you're keeping well!
Yes, other than embroidery it seems there's not a lot you can do with fleece - the ones we have a quite expensive HiViz fleece too!
It all depends on how tight the fleece weave is.
You could try flock, I have used it in the past and it has looked pretty good.
Other than that, if it’s hi vis, you can sublimate it.
Stitch Up
Post by Stitch Up »
I think my only option will be to embroider as heat pressing is going to flatten the fleece as mentioned by justin.
vB_ID:6258
vB_ID:6258
I agree, that weave looks pretty “loose” and, like you have said, it will flatten.
pw66
Post by pw66 »
Text and detail is difficult to press onto vinyl, but a contour cut printed badge is just about ok. You will need to use a very small platen to avoid crushing the fabric, or put a small platen foam pad behind the badge.
Actually PW66 has just made me think of something.
Take a look at the website Ready-Range which has sublimation patches.
I use these on beanies and they work really really well.
Low order quantities, lots of different shapes and sizes and choice of edge etc make them very versatile.
Stitch Up
Post by Stitch Up »
I'm gonna pass on vinyl on fleece - it's not worth the risk.
Thanks for all the suggestions.
pw66
Post by pw66 »
Stitch Up;143933 wrote:I'm gonna pass on vinyl on fleece - it's not worth the risk.
Wise choice. It is just about possible, but in my opinion never gives a true professional finish.
