Circular Coasters
accdave
Re: Circular Coasters
Post by accdave »
I've been asked if I can find some round coasters which are 15cm diameter. All the ones |I can find are 9.5 or 10. Anybody any ideas ?
Dave
Only one that springs to mind is a glass coaster as seen here:
http://www.westcoastprinting.eu/coasters.htm
Not sure if this particular on is available in the UK.
Justin :-)
Can probably get these made for you from the same material as the 90mm square ones. How many are you interested in - might need to be 50+? I can get a quote for you.
accdave
Post by accdave »
Would be great if you could Martin, The customer is enquiring about 2 lots of 28, so 50+ would be good :D
I'll check this out on Monday for you.
accdave
Post by accdave »
Thanks Martin
