New Heat Element
just4yougifts
Re: New Heat Element
Post by just4yougifts »
Hello,
Can anyone recommend where to buy new heat elements? I think ours is broken, this is the mug press:-
http://www.identifyonline.co.uk/product ... /view.ashx
Lynsey
Best to contact your original supplier as the electrics can be different on different elements. What is the connection for your element? A quick connect or do you have to wire it in?
just4yougifts
Yes its a quick connector.
contact coralgraph. they got loads of diferent wraps in good price. give them a shout.
just4yougifts
ok thanks I will take a look
just4yougifts;30367 wrote:Yes its a quick connector.
I'd be careful about just fitting any blanket to your mug press. The quick connector is wired up with 4 holes - 2 take power and 2 take the temp probes. If you just buy 'any wrap' then these might be wired the wrong way round. We have such blankets and when customers buy these from us for other mug presses we sell on the basis that if it doesn't work on your press and comes back to us in working condition then we'll refund, but if the wiring of your mug press has blown the blanket then it's non-refundable. Can your original suppliers not provide a replacement blanket?
