Metal keyrings
barryslip
Re: Metal keyrings
Post by barryslip »
Hi everyone...
I'm trying to find some nice chunky metal keyrings, preferably ones without the metal inserts.
I've tried the "8102 - Metal Rectangle Key Ring" as seen here http://www.hometogifts.co.uk/keyring-metal.html but I was disappointed with the result - the image was hardly visible.
Has anyone else had problems with these ones? Or should I simply give up with these and go for the metal insert type instead?
Many thanks in advance
Barry
NASH
Re: Metal keyrings
Post by NASH »
i use the white inserts and i get great vibrant results
i can`t fault these keyrings
barryslip
Re: Metal keyrings
Post by barryslip »
Thanks for the quick reply NASH. Which ones are you using and also which supplier are you using?
Thanks again
Barry
Andrew
Re: Metal keyrings
Post by Andrew »
Never tried the non insert one other than dog tag type. Can't see why they wouldn't print well if it is a proper item. I use printed inserts as well.
NASH
Re: Metal keyrings
Post by NASH »
i have used both some from Home to Gifts and the last lot i got from BMS equally good but use white inserts
