Epson L110 color adjustment (solve)
bshadown
Re: Epson L110 color adjustment (solve)
Post by bshadown »
For any of those who got into the epson printers with internal ciss, the epson L110 and aré having problems with colors i found a way to get propers colors in case you dont have a ICC, yes i know some people will argue the Ricoh printers aré better, but some people didnt got the info before buying a sublimation printer.
heres the video I made, hope you like it.
http://youtu.be/DyXVj2QffWQ
I would never argue that Ricoh's printers were better than Epson's.
But I would argue that your method is flawed, not as good as you think, and I doubt the results accurate.
I also don't like that you are spreading your idea as an absolute or perfect resolution to the problem.
The fact is that different inks require their own ICC profile, as do different printer models, along with the sublimation papers, and the final substrate all affecting the end colour accuracy.
The only thing I can tell from your video is that your are using an L110 and in your opinion this method works. You show no end products to compare with original graphics, no colour charts. You don't say what ink you are actually using, or what transfer paper, and you don't mention what substrates your method works best for.
bshadown
Post by bshadown »
This metod is the one i found it works best in case you dont have an ICC provided by the manufacturer or you dont own a color calibration system, is not perfect is not bullet proff but if you find no other choice it will work not accurated but better than having colors that are way off, also all the information about what i use is on the video description,
"Epson L110 used for sublimation, the inks are name removed by Admin sublimation inks, the paper is Kronaline sublimation paper letter size (100 grs)
Epson L110 para sublimacion, las tintas son Tintas name removed by Admin para sublimacion, el papel es Papel para sublimacion Kronaline tamaño carta (100 grs)"
yes i know i should have added a video about the mugs and t-shirts printed using those settings but honestly this is the first time i made a video and had no idea how to add more videos to the same one. Again, is better having something close to what you want rather than having none, and if someone gets benefit from the little i know then perfect.
DutchMan
Post by DutchMan »
I have bought the EPSON L110... Can anybody tell me what sublimation inks must buy for phone cover???thanks
Users browsing this forum: Google [Bot] and 0 guests
