Has anyone tried the above combination? I understand a lot depends on the "Fusing Temperature" So far I've been unable to find out what the temp is for the C511DN. It seems the paper is good for below 350 Degrees.
Any help would be appreciated.
Ray
Oki C 511DN & Forever Laser Dark
Re: Oki C 511DN & Forever Laser Dark
Pretty sure mines the 511 and it works a treat with this paper. I've only done a few darks, the Xpres onto white is brilliant.
Thanks Justin that's good to know, can you recall the settings you use?
Many thanks,
Ray
Many thanks,
Ray
Yes, it is the 511dn
Settings pretty much as per instructions, having the Adkins heavy pressure can be useful.
