Pigment Inks, Gel inks, Refillable cartridges,
Re: Pigment Inks, Gel inks, Refillable cartridges,
Post by GoonerGary »
mfatty500;96937 wrote:Is that a wireless 3110dn? I thought that they could not be used as sublimation printer.
It's going to be the same printer only with wireless connection.
Anyhow, here is some info from Sawgrass...looks like you need to check that it will be ok with your operating system if planning to use Powerdriver.
http://www.sawgrasseurope.com/technical ... c-profiles
DJMarkland
Post by DJMarkland »
Hi all, I use a 33110dn for sublimation. It was recommended for subbing.
Honestly would not bother with the refillable inks, they are just cheap ink and will mess up any colour profiles you have.
I was on the verge of paying someone to sort the colour profile and they asked me if i was using genuine....I wasn't and when I did use genuine - Perfect colours every time!!
DJMarkland;97064 wrote:Hi all, I use a 33110dn for sublimation. It was recommended for subbing.
You need a new custom profile if you change inks.
