Start up kit arrived!
Re: Start up kit arrived!
Good luck, lets see your first attempts
Still waiting for a reply from Sawgrass about where they are hiding the Winprofile download on their new site. They did reply to my tweet, and suggested I contacted Technical Support! Which of course, I had already done. I'm thinking I might just install the Powerdriver, could someone explain the difference between that and the WinProfile and why you might choose one over the other? Listawood recommend the WinProfile in their set up instructions.
At least my workstation is all systems go!
- vB_ID:3319
- 20150122_212626.jpg (91.21 KiB) Viewed 351 times
Tidy little setup.
Where are your heat proof gloves and where are you going to put the HOT printed mugs.
Thank you! The gloves are in the cupboard and the hot mugs are going to sit on the mat (to the left of the grill/mug warmer) :biggrin:
Listawood recommended the Win profile to me as well I just seemed to get better colours with PowerDriver, I am using Corel Draw don't know if that makes a difference
malfunction
I hope the mugs end up on the mat on the left and not the bin on the right !!!
Can't see he most important bit of kit - a straight edge to see if the bloomin' mugs are straight:)
Indeed!malfunction;98069 wrote:I hope the mugs end up on the mat on the left and not the bin on the right !!!
I've taken a rule to them - there is a bit of a taper, grrr....malfunction;98069 wrote:I hope the mugs end up on the mat on the left and not the bin on the right !!!
