Doming - Anyone tried it?
Discuss other print methods.
jock
Re: Doming - Anyone tried it?
Post by jock »
I do a lot of doming, anyone thinking about it , the only tip i can give is get a UV light scource for curing as humidity in the air causes blisters
how long does it take to cure when you use UV source?
thanx
GoldRapt
Been thanked: 8 times
Post by GoldRapt »
The real question must be how big a UV light source, in a bed of some sort with a lid or just a light suspended. A4 or A3.?
regards
Tony
-launching july/august 2026
jock
Post by jock »
@Paul , i leave it under for 25-30mins
@GoldRapt , i only use A4 , my uv light is attached to a black sink basin 8) ,
i made myself , the reason being they are too expensive for what they are,easy to make your own
I have two 8 inch tubes
GoldRapt
Post by GoldRapt »
Jock can you pst some photos sometime please so others canbuild one?
regards
Tony
jock
Post by jock »
I will go get a lead for my phone today and get some posted
alan1image
Post by alan1image »
Not sure if the UK have these but been using self adhesive doming stickers here they come in a range of sizes 25mm, 76x25mm, 64x19mm and 25x25mm the most popular sizes.
I use the liquid resin and use a uv curing machine works out very cheap to do.
Just bought a load of keyrings and there's a small recess when the insert is put in, I wonder if this gap could be domed?
cant see why not :) Have you got your doming kit yet justin???
No, not sure where to start just yet, single/double epoxy...uv/heat curing.... :oops:
