Photoshop - designing fonts in multiple layers
Re: Photoshop - designing fonts in multiple layers
��...I have seen me on a bad day try to select copy or Ctrl/command A and nothing happens, stare at the screen only to realise several minutes later that I need to select all to be able to use the copy function. ...lol.
Cheers
Kath
Kath
best laid plans
The best way to represent what your design will look like on a substrate is to create your artwork in photoshop (unless it is text heavy, in which case use Illustrator, indesign). When finished, save it. When saved "flatten" the image - layers, scroll down to the bottom where you will see the flatten option. Don't worry about the white background .... drag it onto the image of your substrate - mug, t-shirt, whatever. On your layer blending modes in the layers palette, change your design layer (the one you have dragged in) from "Normal" to "Multiply" and this is as good a representation as you are likely to get. the "multiply" option knocks out all the white areas on your layer.
