PD2800 Vacuum oven
Re: PD2800 Vacuum oven
No problem at all, happy to help, drop me a message.
The best option is the Sublideck machine. That said these cannot print the newer larger cases, for those you need the bigger A4 sizes machines. These can print all larger cases or two smaller cases at the same time.
Hi Justin
Just to be clear, are you saying that the orange Sublideck machines can not print the MAX series of cases such as an iphone 12 pro max?
Found this point interesting and want to make sure I understood it right.
Yes that's correct. There isn't enough space around the jig to allow for a good vaccum.
Do you mind me asking what the make/model is of the larger vacuum press?
These are Chinese made machines that we are distributing.
