THHHHHHHHHHHHHHUUUUUUUUURRRRRRRRRRRRPPPPPPPPP!(waits for the puns to start about a F machine now...)
There you go Martin :biggrin:
It's one I bought from you Martin the 30cm x 38cm swing away press I just assumed it was centrigrade it's pressed all my HTV fine so far anyway!bms;58310 wrote:Is you press 190 degrees C or 190 degrees F? Does the display go up to 350-400 - if so then it might be a F machine (waits for the puns to start about a F machine now...)
ok I think I can the profile from the seller ......Ian M;58313 wrote:You really do need an ICC profile to get the correct colours & you will have to have a custom made one because, the Epson S22 isn't a supported printer.
Where did you buy the inks from?
With the Epson I selected the photo setting as it was a photo I was doing not the "best" setting. You get several options including text, photo, best photo, text and image or draft.Paul;58317 wrote:I think you also print on "normal" setting of your printer if image is ok on paper.
Yes that is a C machine. Sorry if I didn't recall you bought this from us - the DSF pseudonym means very little to me unless it's an acronym of your account reference with usmummywebb;58312 wrote:It's one I bought from you Martin the 30cm x 38cm swing away press I just assumed it was centrigrade it's pressed all my HTV fine so far anyway!
From a reputable supplier ?mummywebb;58308 wrote:It was advertised as sublimation ink it came in refillable cartridges
bms;58320 wrote:Yes that is a C machine. Sorry if I didn't recall you bought this from us - the DSF pseudonym means very little to me unless it's an acronym of your account reference with us
Well not a licenced one anywayaccdave;58321 wrote:From a reputable supplier ?
