Help with iphone cases please
sehmus99
Re: Help with iphone cases please
Post by sehmus99 »
JMugs;68139 wrote:If the image looks good when you look at it square on, then you are getting the fine pattern from the platen or its cover, use a silicon sheet between the platen and the paper. this will smooth everything out. if the image is poor when you look at it square on then ignore the above.
Not saying I have the answer, just the answer to a problem I had in the past.
Janners
Yes exactly like that when you look at it straight on it look good but when you look from an angle you can see that its not smooth.
any idea where i can get a silicon sheet from?
AdamB
Post by AdamB »
pisquee;68151 wrote:Are your covers kept somewhere nice and warm and dry, or somewhere cold and/or damp?
If the latter - it could be a moisture thing -- pre press them before using,or put them somewhere warm before using
I would say for metal that it's more important to make sure your 'transfer' is completely dry, rather than pre-pressing the metal (I know there will be a very, very small amount of moisture in metal but it will be minimal compared to something like a placemat) - unless the metal is stored in a very damp place.
Once a print is done, hover your press over the print (not touching it - a few inches away just to dry the print out). Some conde videos also recommend this (and it works) as some papers take a lot longer to dry than others.
I pre warm these pieces then press with the metal up (opposite way to usual) I put sheets to and bottom and cover the press lower base with as smooth sheet, silicone etc. As little pressure add possible when closing the press.
