Cutter Help
Re: Cutter Help
This is a good point, also bear in mind the Cameo loads from the front and pushes out the back unlike larger cutters
tlworkwear
Re: Cutter Help
I've cut a few 2 metre signs with no problems on my cameo. The only time the vinyl has slipped is when I've cut it down to 12" myself
- bespokevans
- bespokevans
- mrs maggot
Re: Cutter Help
tl, they are 30cm (300mm) not 3Mtr designs so i cannot see why he would have an issue with them ? on any cutter.
tlworkwear
Re: Cutter Help
the OP said that they wanted to cut a 300mm x 3000mm design unless I read it wrong.. I'm on mine ipad and can't be bothered to go back a page lol but will check later. I'm sure it was a 3m design though..mrs maggot;75436 wrote:tl, they are 30cm (300mm) not 3Mtr designs so i cannot see why he would have an issue with them ? on any cutter.
@bespokevans I got a promacut PC720 which took me a while (and a lot of help!) to get working but it can cut up to 630mm and seems pretty good. Having some issues finding spare blades for it though as the manufacturers won't reply to my email lol.
Re: Cutter Help
I am as a person who doing metric for 33y now
i can confirm 3000mm is 3meters
- bespokevans
- mrs maggot
Re: Cutter Help
my bad then, i must have read your original bit wrongly
