Show off thread :)
Designandgift
Re: Show off thread :)
Post by Designandgift »
wow
all you guys are creative
i am just starting to take the plunge now, quit my job 2 weeks ago and hope to create a small business
i hope i am as good as most of you guys after a while :)
i like all the images, i may start doing them slates that was first posted by Paul...
Great ideas
Carl
Design and gift
NikGrey
Post by NikGrey »
It was with the Liyu as this was too big for the Cameo - Still not had a chance to have a proper play with the Cameo. The carrier sheet seems very sticky and is no good for printer paper.. I'm worried it will deform my transfer sheets if I have to use that sheet :(
gorgall2
Post by gorgall2 »
Did these with vinyl, bugger to weed.[ATTACH=CONFIG]2029[/ATTACH]
vB_ID:2029
vB_ID:2029
drugbuster russia.jpg (55.95 KiB) Viewed 764 times
windyash
Post by windyash »
Just looked through here and theres some good stuff going on :smile:
Bit embarassed to put anything ive done on here now !!!!
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
windyash
Post by windyash »
[ATTACH=CONFIG]2132[/ATTACH]
Heres my first couple of mugs , 1 using my advert that is going in a local free booklet and the other is a picture I took the other evening on the way home from work .
Quite happy with them :cool:
vB_ID:2132
vB_ID:2132
Look good windyash, nice black on the photo
windyash
Post by windyash »
Cheers , I was very pleased with how the photo came out , after reading many horror stories about black !!!! I only pressed for 80 seconds after reading the BMS site , they said that good results had been had by less time
mikeoooze
Post by mikeoooze »
T Shirt Using Pro Flex from MDP....sold a few on Ebay. :smile:[ATTACH=CONFIG]2173[/ATTACH]
vB_ID:2173
vB_ID:2173
windyash
Post by windyash »
Cool design , been testing out the MDP flex over weekend , with good results
Dave271069
Post by Dave271069 »
I use mdp flex all the time, I'm very happy with it so haven't experimented much with other stuff, mind you I did use TMT 123 flex the other day on a sublimated poly apron and it was nice to weed in fact extremly easy and pressed at 120c.
