starworld sublimation t-shirts
Re: starworld sublimation t-shirts
just had an email from starworld. out of stock for 6-8 weeks...
leethesign
leethesign
On thesubject of sublimation t-shirts - has anyone tried using just ordinary Polyester t-shirts?
It appears that the sub shirts are polyester on the outside and cotton inside, makin them a quite heavy shirt, and
the plyester ones are quite a lot thinner.
Oh...and how can I stop the function that replaces letters that are typed incorrectly? If I miss out a letter and put it back in
I have to re-type the rest of the line, or it's all wrong!!!
When is this happening Lee? Not sure I understandleethesign wrote:Oh...and how can I stop the function that replaces letters that are typed incorrectly? If I miss out a letter and put it back in I have to re-type the rest of the line, or it's all wrong!!!
Probably pressed the INSERT button on your keyboard - press it again and it should work.If I miss out a letter and put it back in I have to re-type the rest of the line, or it's all wrong!!!
Have you see or felt a 100% polyester t-shirt? Some of them are v-e-r-y slimy. The Vapour style are much better to feel.
leethesign
Ah, let's try.........abcdefgijklm................no I left out the "g" and when I inserted it, it overtyped the "h" oh s**t- it?s doe it again......ABCDEFGIJKLM see---done it again. Overtype is on and I can't turn it orf!
Has to be a setting on your keyboard. Try doing the same in Word (or whatever else you use to type letters) and it will probably do the same. On my keyboard I have INSERT just above DELETE and if I press INSERT accidently then it will over type letters rather than moving the line along as I type.
yes. only sublimation t-shirt.leethesign wrote:Just the sub shirts I imagine Paul...not everything!!!
leethesign
Yep Professor......thanks - that's done the trick.......simple when you know how ain't it?
Well, I won't be using them thenPaul wrote:just had an email from starworld. out of stock for 6-8 weeks...
Users browsing this forum: Baidu [Spider] and 3 guests
