Ricoh OR Epson ??? New Printer Which to Buy?
Mugsman
Re: Ricoh OR Epson ??? New Printer Which to Buy?
Post by Mugsman »
i got both 7000 and a R1900 Ricoh all the way for me
smitch6
Post by smitch6 »
welcome to the forum
skru
Post by skru »
bms;18306 wrote:Do you have the Ricoh printer already? If not then we have the Ricoh and SubliJetR cartridges at:
Thanks !! I will use them as I now from USA forum SubiJetR is one of the best ! Is that true that when You start it first time and placeing cartridges , filing up all pipes "charging" use 80% of gel ??
Thanks bms and Justin !!!
Hello smitch6 :)
You will use up around 25-40% of the ink from just 2 cartridges as the printer has 2 print heads. One print head is connected by a longer tube that the other so as the printer primes the ink for the first time some ink from 2 of the cartridges has to fill the tubes, hence the levels drop in 2 of the cartridges, but it's not by 80% and not all 4 cartridges. You don't loose the ink, it just comes out of the cartridges and into the tubes, so none is wasted, but the cartridges do drop in levels.
Kaz
Post by Kaz »
Martin
When I first put the subli carts in my 7000, all 4 levels dropped to about equal measures :(
skru
Post by skru »
Martin do bms going on sign&digital with stand this year ??
Comments below related to GXe3300 as that was what the thread was referrring to. The GX7000 also has 2 printheads, but less sure about the lengths of the tubes to each printhead on that printer.
Sorry no, far too busy to have the luxury of time away from the office for a show!
