Unisub Coaster Backs - Getting Worse
Andrew
Re: Unisub Coaster Backs - Getting Worse
Post by Andrew »
Subli.co.uk have them I believe although they are not branded as Orca on the site. 9cm square hardboard coaster. Would think they are the same as the ones I had which were bought direct from China.
technick
Post by technick »
I've had a chat with Xpres today about the decline in quality. They are fully aware and are currently in talks with Unisub as there have been a few complaints. I will take a look at Subli coasters but doubt they will live up to the quality tbh. Like Olly mentioned.... If you are using the Unisub coasters and noticing a decline then stamp your feet and make your voice heard:)
Ali P
Post by Ali P »
I would be very interested to know if there has been any change in quality of the unisub coasters since the last comments (April)... or are they still to be avoided?
technick
Post by technick »
I still use them as there are no other suitable alternatives available. The only other coaster i would be comfortable using would be BMS but logistically doesn't work for me (Parcelforce).
Going through approx 800-1000 per week, any duds (usually markings on the white coaster area) i place in a pile and sent back one a month. As long as you remove the heat tape off the backing before the coaster starts to cool down you shouldn't have any tears.
Post by GoonerGary »
I needed a new coaster this week which was a toss up between the Unisub or the BMS coaster. Both were 54p delivered, so went with the Unisub from Xpres which was delivered next morning compared to a week's wait with BMS and Parcelforce.
I had no problems with the backing on the Unisub 3/8/17 batch, using Xpres 6006 tape and removing immediately. Dust issue yes, but a quick swipe with a Scotch Brite lint remover done the trick.
technick
Post by technick »
Batches beyond July last year seem to have better backings Think the message got through to them eventually
