Get a life bigj2552! As if I would ever send you one of my skirts - go buy your own lolbigj2552;51003 wrote:oh for goodness sake - i told you not to tell anyone....that was our little secret.
anyway, i can now send this skirt back to you in the post...it didnt fit me properly.
thanks for sending it anyway...the thought was there
...maybe ....to much thought...ROFL
Cutter .. Cameo ?
- WorthDoingRight
Re: Cutter .. Cameo ?
well,thats me buggered up my cutting mat......
had to trial n error all the settings again as i went back to the older software :rolleyes:
off to buy another mat i suppose.....:rolleyes:
You must have pushed the setting right up at the start then?bigj2552;51108 wrote:well,thats me buggered up my cutting mat.......
If testing a cutter - always start off with too little pressure and work up with a test cut.
AdamB;51109 wrote:You must have pushed the setting right up at the start then?
lol...yep, how you guess......lesson learned again
- WorthDoingRight
Sorry to hear about your cutting mat biting the bullet. My transfer tape has still not arrived so now assumed eaten by RM. I did however purchase some rhinestone software so made a template out of sandblasting film (so much easier to cut than the flock) and used this to lay out some stones. Would have been much more successful with tape but the result is pleasing for a first attempt.
[ATTACH=CONFIG]1125[/ATTACH]
- vB_ID:1125
- IMG_0001.jpg (108.58 KiB) Viewed 412 times
All those rhinestone designs look good to me , Im yet to attempt using rhinestones. Anyone got any good links to videos on learning the basics ?
Cheers
Cheers
is that the same princess writing/rhinestonesthat you told me about that you put on your boxers to impress the ladies ?WorthDoingRight;51290 wrote:Sorry to hear about your cutting mat biting the bullet. My transfer tape has still not arrived so now assumed eaten by RM. I did however purchase some rhinestone software so made a template out of sandblasting film (so much easier to cut than the flock) and used this to lay out some stones. Would have been much more successful with tape but the result is pleasing for a first attempt.
i dont know....some guys will do anything to get the woman
- WorthDoingRight
No my first attempt with the same red flex was 'May Contain NUTS' which was pressed on the front of my briefs.bigj2552;51304 wrote:is that the same princess writing/rhinestonesthat you told me about that you put on your boxers to impress the ladies ?.
I then put a smiley face with rhinestones on my wife's undies.
I wonder if you are mistaking the 'princess' on my boxers for my tattoo? You know the one I told you about that says LUDO most of the time and LLANDUDNO for some of the time :rolleyes:
Sandblasting cut very nice and stones go in to the holes easy. Crap bit is when you apply tape. It sticks to sandblasting vinyl so much that you need to use bit of force to get it off. And then loads of stones are coming off.
- WorthDoingRight
Well as I have not received the transfer tape yet (I ordered 2 weeks ago but it failed to arrive) I am unable to prove the point but I did wonder. I am also going to try cutting a template from another material that I have now received and see if that works also.Paul;51310 wrote:Sandblasting cut very nice and stoned go in to the holes easy. Crap bit is when yo apply tape. It sticks to sandblasting vinyl so much that you need to use bit of force to get it off. And then loads of stones are coming off.
If I can be bothered to put a 60 degree blade in the holder then I might try cutting that flock that Johnny put me onto again - it cut really badly with a 45 deg blade.
