Simple Mug Render
stevepburgess
Re: Simple Mug Render
Post by stevepburgess »
Hi folks
I've created a simple tool to enable me to create images of mugs without having to print and photograph actual mugs. It's not a full 3D render. It simply creates a front view, a side view and a rear view and the design is "printed" onto a photograph of an actual mug rather than a 3D rendering of a blank mug. The images have a white background.
At the moment, only the 80x92 Durham style mug is supported as this is the mug I generally use. I'm also going to add the BMS Strait Bone China mug.
The system lets you change the upper and lower margins and the space around the handle. You can also specify whether you want to fill the printable area (and thereby crop the design) or fit all the design in.
It's available on my website and there is a sliding scale of charges depending on how many designs you render at a time. If you want to give it a try it's here
vB_ID:3400
vB_ID:3400
Cheers
Steve
