I've been asked to do some Rhinestone designs so got some stones and Stencil Material from TTP while ordering some sublimation items.
I have a Graphtec CE6000-40 and wondered if anyone was using this to cut the TTP Stencil Template Material. If so, then does anyone have the cutter settings?
Keith
Graphtec Settings for TTP Stencil Material
- ASO Embroidery
Re: Graphtec Settings for TTP Stencil Material
Hi Keith
I too have a Graphtec ce6000 sorry missed your post if your still needing details let me know and I can let you have them. What type of stencil material are you using is it the sticky back stuff that you put on card.
Sammy
Sammy
Hi Sammy, going to to try cutting this week so good timing! I have this material http://www.thetransferpress.co.uk/stenc ... 2x16878629
i was going to try the pink stuff from yolo too as I see some earlier posts recommend.
Keith
Keith
Hi Keith, go to You Tube and put a search in for The Rhinestone World. They have a wealth of videos on using the pink flock for Rhinestones. Oh nearly forgot they use the Graphtec as well on some of the videos. I will try an add some links after I get my granddaughter to school and walked the dogs ��
Cheers
Kath
Kath
Here is a quick video from TRW using the Graphtec. There are loads more, showing things like layers and making an easy work table. To many to list here.
Hope this helps
http://youtu.be/fLr0ltuw3p8
Hope this helps
Cheers
Kath
Kath
Thanks Kath. I will have a look.KathG;108673 wrote:Here is a quick video from TRW using the Graphtec. There are loads more, showing things like layers and making an easy work table. To many to list here.
Hope this helps
Keith
