Page 1 of 1
Re: Photo Rock Slate Blotchy
Posted: 08 Dec 2016, 16:26
by Bob the printer
Photo Rock slate is not transferring properly.Paper sticking to slate.
Products/Equipments:
[TABLE="class: custom-data]
[TR]
[TD="bgcolor: #E4F1D8]Ricoh SG7100DN, Xpres A3+ Paper, Sublijet r ink, Rock Slate,[/TD]
[/TR]
[/TABLE]
What I have tried to resolve problem:
I have tried changing the temperature, the time and pressure slightly as suggested by other sights.
Ensured print was dry on paper before pressing.
Pre-cooking slate to ensure no moisture.
Used silicone pad.
Slate is face up, print face down.
Made sure printed on correct side of paper.
vB_ID:4363
vB_ID:4363
vB_ID:4363
vB_ID:4363
vB_ID:4363
vB_ID:4363
Posted: 08 Dec 2016, 21:56
by Tam
You are not alone, have a look over here. One of my slates
vB_ID:4364
vB_ID:4364
Posted: 09 Dec 2016, 15:40
by harlequeen
Yes, I have similar results - are these a new batch of slates recently? All the newer ones I'bve tried to print have come out like this.
Posted: 09 Dec 2016, 17:36
by Tam
Got my first batch 9th Oct for testing got second batch 27th Oct. You can see the first batch are far more glossy looking.
I had a matte in the first batch and it was the best by a long way.
I got them from Merlin Transfers and will be contacting them soon!
Posted: 17 Jan 2017, 17:12
by surreyprintshop
Hi All,
I am looking for some advice if possible.
I am trying to sublimate some photo rock slates but the image quality is really poor as if its not transferring properly.
I am using ricoh printer and sawgrass inks.
The slates came from longforte.
The settings i use is time 8 minutes temp 200 degrees.
I sublimate with them facing down so the heat goes through the slate.
Any advice of what i could try would be welcomed.
You can see the image of what im getting here or via this url https://drive.google.com/file/d/0B3P5cK ... lReFk/view
Look forward to hearing from you.
Posted: 17 Jan 2017, 17:57
by scotty44
surreyprintshop;119474 wrote:Hi All,
I use the same printer/ink/slates and time and do mine face up, works fine for me... worth a try ;)
I do put a rubber sheet on top of the slate so it's not direct heat from the press..
Posted: 17 Jan 2017, 18:45
by Paul
try my video. is bit outdated and show matte slate but worth to have a go. I would lower your temp down. flip it printable area up and use silicon sheet to even out the temperature.
Posted: 19 Jan 2017, 09:59
by surreyprintshop
Thank you for your reply's.
I will give it ago today to see if i have any luck using the methods that you suggested.
