Hi, I bought a 2nd hand printer which had sawgrass r inks installed.
the cyan is almost empty but the other 3 are still fine, can I get away with just buying the cyan cartridge and will I need a new ICC profile.
Sorry it its a daft question but I m new to this.
ink cartridges
Re: ink cartridges
Just replace like for like cartridges so replace with the same Cyan cartridge from Sawgrass. No updated profile is required as the ink is already correctly matched.
Re: ink cartridges
you will need to install the correct profile if it is a new printer to you, but the new cyan will work just fine provided the other inks are reasonably in date
