Page 1 of 3
Re: Red is orange after press
Posted: 01 Nov 2018, 09:15
by Maartje
Hello,
So I will try to explain as best as I can, I am from the Netherlands and my technical English is not that perfect.
I have made a design in Photoshop and printed it with my Ricoh 3110DN. The print looks perfect. But when I press it on the fabric it does not come out as red as it is supposed to, but it comes out orange.
I printed something a few weeks ago and the skincolour also did not look right, it was too yellow.
I pressed for 1.30 minutes with a temperature of 188 degrees Celsius.
I have the settings and stuff like that as was instructed. So what can I change to have the proper colours on my fabrics?
Hopefully a sollution that is not too technical ;)
Thanks,
Maartje
This is how it looks on the fabric:
vB_ID:5458
vB_ID:5458
This is how it looked in Photoshop:
vB_ID:5458
vB_ID:5458
Posted: 01 Nov 2018, 09:57
by webtrekker
A sublimation print should not look perfect. The print itself should look washed-out and colours will be way off what you expect, but when pressed it will look great.
I suspect you are not using an ICC profile, or not using it correctly, when printing your transfers.
Posted: 01 Nov 2018, 10:21
by Maartje
Is this the ICC profile? I chose the settings of the Sublijet print setup guide ...
vB_ID:5459
vB_ID:5459
Posted: 01 Nov 2018, 11:06
by knightweb
Hi, Can you post the page that comes up when you select "Print" in Photoshop
Posted: 01 Nov 2018, 11:58
by Maartje
knightweb;134998 wrote:Hi, Can you post the page that comes up when you select "Print" in Photoshop
vB_ID:5460
vB_ID:5460
Posted: 01 Nov 2018, 12:14
by knightweb
Hi, For Printer try selecting "Power Driver", I'm assuming that you have Power Driver from Sawgrass installed?
Posted: 01 Nov 2018, 12:22
by Maartje
Yes I have the power driver installed from sawgrass.
So I chose this one:
vB_ID:5461
vB_ID:5461
Nothing comes out of the printer :(
Posted: 01 Nov 2018, 12:28
by webtrekker
'printer beheert kleuren translate' ............... does that mean 'printer manages colours?'
In Photoshop, it should be 'Photoshop manages colours.'
Posted: 01 Nov 2018, 12:32
by Maartje
Yes that means that the printer manages the colours. I will change it and try again!
In the Sawgrass instructions it says that the printer has to manage the colours ...
Posted: 01 Nov 2018, 12:41
by knightweb
Yes try Power Driver, that's what I use, ( I have Printer Manages Colors set)
