Hi guys i am currently using sublimation ink from cityinkexpress in a Ricoh printer and a Mac, I wanted to know if I change ink say to sublinova do I need to get another icc profile made up?
And if anyone has one what your opinions in comparison off the 2.
Changing ink supplier
Re: Changing ink supplier
Hi. I use CIE inks and paper with a profile supplied by them and get great results. If you were to change inks you'd need a new profile to match the new inks and you'd also need to flush out your old inks. Remember that refilling with the new inks will use up quite a bit of them just to fill the printer's ink lines.
