Polyester Printing HELP!
mikeq
Re: Polyester Printing HELP!
Post by mikeq »
Evening guys help required I’m printing sublimation using Epson WF7210 using trupix paper and fotorite ink from ink express, every time I press at 190c for 60 seconds I get big shiney square scotch on the garment how can I overcome this?
mrs maggot
Post by mrs maggot »
the scorch marks you are getting can you post a photo, is it the same size mark every time ? what are you putting over your garment ie silicone paper ? or is it just the heatpress and the paper ?
mikeq
Post by mikeq »
mrs maggot;139410 wrote:the scorch marks you are getting can you post a photo, is it the same size mark every time ? what are you putting over your garment ie silicone paper ? or is it just the heatpress and the paper ?
ill try and post a photo, it’s the whole heat press square making it shiney, using paper and greaseproof sheet
pw66
Post by pw66 »
What garment are you using? What colour? What colour is the scorch mark.
Try backing off the time, temp, and pressure - experiment til you find a sweet spot
Is the outline the mark of the paper (if so make your paper bigger than the press or tear the edges to soften them from being sharp)
mikeq
Post by mikeq »
A look at how it is
vB_ID:5831
vB_ID:5831
Mrteajunkie
Been thanked: 3 times
Post by Mrteajunkie »
Is that printing a yellow tint to the paper?
So when you print does it print just the image and then spit the paper out.
Or does it continue for a while then spit the paper out?
pw66
Post by pw66 »
Have you been printing hi-vis or bright coloured polyester?
Is your cover paper leaching something onto the fabric when pressed?
