just bought a 53" cutter from a guy but didn't come with driver
It has on screen rabbit and on back the number says 1360 after googling i think it's a HX1360 rabbit cutter but i can't find the driver
Can anyone help i've attached some pics
Rabbit cutter help
Re: Rabbit cutter help
- vB_ID:103
- DSC00061.jpg (81.51 KiB) Viewed 239 times
- vB_ID:102
- DSC00060.jpg (84.86 KiB) Viewed 239 times
- DSC00061.jpg (81.85 KiB) Viewed 239 times
- DSC00060.jpg (85.2 KiB) Viewed 239 times
Matthew
Which software package are you using for cutting?
If you have FlexiPro, you shouold find the driver in there.
You could try contacting the manufacturers for the driver, if googling for it fails
http://rabbitlaser.en.made-in-china.com ... 1360-.html
Just found this, does it help?
http://aspgfx.com/download/rabbit+hx-13 ... +free.html
I clicked the first link and it wanted to install the required driver, afaik
Kaz;15946 wrote:Just found this, does it help?
Just clicked link you can only download if you sign up to website
Matthew
Kaz;15945 wrote:Which software package are you using for cutting?
Hi Kaz
I'm going to use Artcut 2009 if i can, i've just sent company email to see if i can get driver if not i'm just gonna sell it can't be chewed with it
Matthew
Found this site aswell
http://www.eurosystems.lu/index.dml?unt ... prache=eng
Might be better selling ti on if no joy with locating a driver for it.
I had similar problems with my Liyu, couldn't get a driver, but Vista recognised it as being a roland, if memory serves me right.
If artcut 2009 is the same on set up as the 2007 try open manufactors click on others then HPGL or DMPL your cutter should use one of these commands.
