B1100 won't turn on????
smitch6
Re: B1100 won't turn on????
Post by smitch6 »
typical why do things always go wrong when you get an order??????
i just went to turn my epsom B1100 on to print an order out and it won't power on at all?????
yes i changed the fuse in the plug for one i know is good :)
anyone got any ideas pls ????????
Matt Quinn
Post by Matt Quinn »
I'm assuming the machine has an internal power supply? i.e. the mains lead plugs straight in to it?
1) Try another mains lead (preferably off something known to work) - Or try the printer's lead on something else.
2) Test the socket by plugging something else in to it
Failing that it's an internal issue - possibly as simple as a fuse - but you need the help of somone who knows a bit about electronic repairs; fuses generally fail for a reason.
IF the machine has an external Power supply try and borrow one from somewhere and substitute that.
smitch6
Post by smitch6 »
tried both them things :(
dif lead and tested the socket it's a bog standard twin wired lead the type that we used to use on cassette players (i'm showing my age now lol)
gstk
Post by gstk »
with the power lead out - hold down the power button for 30 seconds. Then try. If still no luck plug the lead back in and hold the on button down and the paper feed at the same time. Sometimes works and doesnt cost anything to try.
smitch6
Post by smitch6 »
tried that :(
just tried connecting to the printer utility to see if there's anything there at all and it doesn't connect to that either so there's defo no power in the unit
i am hoping it's an internal fuse somewhere but how on earth do you get into these things lol
R.Prints
Post by R.Prints »
Got myself a B1100 recently so nothing I can tell you, but am interested in what you find out for future incase I end up with same problem. Good luck.
smitch6
Post by smitch6 »
i managed to get it stripped out lol bits everywhere (they don't make these things easy do they? )
i have found the internal fuse thats ok and i touched a bit on the board and it gave me 1 hell of a shock so it's holding the power within the transformer thing lol (and yes it was unplugged :P )
i've checked the board for connectivity etc and dry joints and everything seems ok so i reckon it's on the other board which is the low voltage side which has loads of terminals and connectors etc on
so anyone wanna buy an epson B1100 in bits for spares? :(
even got a near enough full bulk feed system for it
why do you want to sell ink with it? would not be any more sense to connect to your new printer?? You can get brand new one here for under £150. you can sell oryginal carts and it will cost you even less ;) so you get brand new printer with 12mc warranty...
smitch6
Post by smitch6 »
but as soon as you install sub system the warranty is void :(
only if you tell them ;) if you return printer with oryginal carts instaled it should not make any diference. fair play if heads are knockered but i am preety sure that type of ink has nothing to do with power system :)
edit:
any way... where did you bought your ink from??? if you use sawgrass then they may be able to help you as you use suported ink and printer :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
