Refill ArTainium CIS
theemmanewman
Re: Refill ArTainium CIS
Post by theemmanewman »
Hoping someone can advise how to refill ArTainium CIS - bought from Martin for Epson B1100, I can find the box and every bit of wrapping etc that came with it, but instructions? Not a chance! I know they are somewhere safe, unfortunately can't really tell people that they can have their orders when I find the instructions, so if anyone could help I will be eternally grateful.
Unplug big bung, pour ink in, put back big bung! :)
jennywren
Post by jennywren »
simplees, you'll need a syringe, I use a different syringe for each colour.
theemmanewman
Blimey glad I asked, wouldn't want to do that in the wrong order! Thanks Martin, am now feeling extremely silly.
AdamB
Post by AdamB »
bms;27790 wrote:Unplug big bung, pour ink in, put back big bung! :)
It's funny because I need to fill mine up and have been leaving it ............... when you say 'big bung' Martin this is the 'bi bung' in that leads to the smaller front container? All ink levels in the front container are level, with the rear container having the fill line on it ............... not to confuse the matter :)
There are a couple of different designs on the EasyFlow systems. With the one you refer to, you do the same, but when the shorter side is full up you tilt back the system so the ink goes into the larger section. The ink doesn't flow back again to the small section (just like magic!). Repeat as necessary to fill the larger section.
AdamB
Post by AdamB »
Got ya ..............
bms;27797 wrote:The ink doesn't flow back again to the small section (just like magic!). Repeat as necessary to fill the larger section.
How does this work then .............. sorry! just curious how it doesn't go back through to the smaller section.
purpledragon
Post by purpledragon »
Ive heard of dumbing down instructions martin but thats the best yet !!! what next how to print a mug "put ink on paper put paper near mug make mug hot UGG" lol
AdamB;27798 wrote:Got ya ..............
Told you... it's magic! :)
purpledragon;27809 wrote:Ive heard of dumbing down instructions martin but thats the best yet !!! what next how to print a mug "put ink on paper put paper near mug make mug hot UGG" lol
....I'll have to change our instructions online now...:)
