postage problems
Re: postage problems
Quickly who do you use to post mugs and what packaging do you use, also what does it cost you, I am having breakage problems far too many, thanks in anticipation Tony
- mrs maggot
polystyrene mug mailers seem to be the only way to get them there without breakage, also there are some heavy duty cardboard ones, which i have not tried, never had an issue with the poly mailers
I use cardboard boxes that they say you can bounce and the mug won't break, I brought in bulk and they work, but I've forgotten you I've got them off, maybe someone else can recommend, all I can recommend they do work, I've not had a breakage in the last year.
www.subli.co.uk these sell them hope that helps I can only tell what experience that I've had with them which has been good
Thank you just seen subli sell some blow up ones as well, spoke to them and they reckon these are very good as well.
I cut down the boxes I get my vinyl in with plenty of bubble wrap and paper shreds
I use inflatable mailers in a box. Not a cheap option but 50% of my sales are export. Never (literally!) had a broken mug using this option.
For a client I print for the UK stuff goes out in Poly boxes and they are fine. They aren't big enough for address / customs / fragile / airmail / postage label for abroad though.
So called cardboard mug boxes drove me nuts with breakages...just my experience as others say they are fine.
Janners
Janners
