High Temperature vs Low Temperature Sublimation Ink??
astroanalyst
Re: High Temperature vs Low Temperature Sublimation Ink??
Post by astroanalyst »
I have vendors telling me there is a difference between High Temperature Sublimation Ink and Low Temperature Sublimation Ink for making phone covers.
Is there such a difference?
ArferMo
Post by ArferMo »
yes there is and the gassing point is 30 or 40c lower.
astroanalyst
they say that the lower temperature ink yields better results when using film... is that true?
ArferMo
Post by ArferMo »
its a film provider that also provides the low temperature ink its a sort of package matching ink for the expensive film.
astroanalyst
Ok so my next question is can you recommend a vendor who sells both film and low temp ink for this purpose of sublimating phone cases?
I have a vendor in China but I'm not sure I trust him.
I live in the United States.
By the way there are no good Sublimation forums in the US!
astroanalyst
Also what temperature range does low temp ink work in?
astroanalyst;105639 wrote:I have vendors telling me there is a difference between High Temperature Sublimation Ink and Low Temperature Sublimation Ink for making phone covers.
Interesting concept, but if this is the case why does ordinary Sawgrass SubliJetR sublimation ink work fine in the industrial 3D machines that sublimate at around 140 degrees? The inks we've supplied have never been modified and they work fine. Just an observation!
Ucase Ltd
Post by Ucase Ltd »
astroanalyst;105648 wrote: By the way there are no good Sublimation forums in the US!
Don't Conde have member section?
ArferMo
Post by ArferMo »
Because Rico ink is a slightly lower temperature ink than the epson, though everyone knew that.
