ST 3042 No power ...Any idea please help
3D Sublimation
Ravisteam
Re: ST 3042 No power ...Any idea please help
Post by Ravisteam »
Hi , My ST3042 stop working today and it shows no power at all ..Any idea why ??. Do they have a Fuse at all ?..any one know ?.....Could it be the power board >>??...Please help me asap ..Thanks for your help in advance ..Rav
Brixhamboy
Post by Brixhamboy »
Hi Rav,
you need to take a structured approach to problems like this. Begin with making sure there is power to the wall socket. Do you have something else you can plug in and switch on?
Once you can be certain there is power the next stage will be the fuse in the plug for your ST3042. Do you have a test meter by any chance? If not, the best way is to replace the fuse with one from another appliance you know to be working. The mains lead is probably a 'kettle' type which plugs into your heat press so perhaps you have a similar lead in another electrical item. Just be aware that the fuse will almost certainly be 13 Amp so if you test your press with a lower rating fuse it will probably blow.
If it is not the plug fuse then there might be a fuse on the press itself - sometimes it is part of the socket into which the mains plug fits. I am not familiar with your press specifically, but have spent decades of my life fixing photographic processing equipment which is similar.
Let me know how you get on
Stu
Quinsfan
Post by Quinsfan »
Rav there are several post on this subject on this forum. I don't have one of these myself but from reading up about them on here the wires seem to come loose inside it or get pinched when the lid is closed.
Brixhamboy
A quick point on safety; It might well be something inside but with anything electrical it is ill advised to open it up and go poking around unless you know exactly what you are doing and how to do it safely.
Ravisteam
Post by Ravisteam »
Brixhamboy;105955 wrote:Hi Rav,
Stu
Hi Stu thank you so much for taking time to help me out ...Ive done all you said but there is no fuse ..I had a little look around to see if there is any fuse inside but no luck ..And I had a little search on net but no one talk about a fuse ..Many videos are to show how to replace the main board ( about £50 -70 ) ..It was working fine and our power went off for 5 mins and come back and machine is dead ..I thought the same thing could be easy fix ( Fuse ) ...But to check if there is a fuse inside I have to strip it down and seems a bit of hard work and also as I wasn't so sure there is a one I thought to get some help from the forum ......Ill try to contact the Chinese supplier I bought this from ( 3years ago and machine worked well till today ) as I can see they are selling boards too...Ill update ..Thanks again
Ravisteam
Post by Ravisteam »
Quinsfan;105956 wrote:Rav there are several post on this subject on this forum. I don't have one of these myself but from reading up about them on here the wires seem to come loose inside it or get pinched when the lid is closed.
Hi Ian , thank you so much for trying to help me ..I had a little look around the forum but nothing smiler to my case (Complete dead ) ...Hope some one might help ..Thanks again Rav
Brixhamboy
Hi Rav, there won't be a fuse inside the machine - well, extremely unlikely.
If you had a power out with your supply and the machine died on restart then it is highly likely it blew the mains fuse in the plugtop because of the surge in power as it pulled power for the elements, vacuum pump etc all at the same time.
Second to a fuse I would be looking at the next weakest link - what ever handles the power switching. If the unit had not been run for a while there is also the possibility of the heating elements (which are filled with a type of sand) becoming damp. If you've ever had an electric kettle fail you might have seen a small hole appear in the element (okay, so I am old and remember when you could still see the heating elements).
Unless it is the fuse in the plug I would recommend you do not attempt to dismantle this yourself because of the potential risk to life.
Maybe double check the fuse that will certainly be in the wall plug???
Good luck
Ravisteam
Post by Ravisteam »
I have checked the plug top and even swap another. .no luck...might buy another faulty and try to swap parts. ..I am good at pc repair so it might help lol..Thanks again
mark91740
Post by mark91740 »
Hi, I am having the same issue. No power to front panel when the unit is turned on. Did you ever find out what the problem was? Thanks for your response.
Ravisteam
Post by Ravisteam »
Yes mate ..replaced the board and all good now..
