Bit of info please
abacus1983
Re: Bit of info please
Post by abacus1983 »
Hopefully in the right place here :)
I have a sublimation setup, but an looking into transfer printing for cotton T-shirt, I know this requires a new setup so I have a couple of questions.
1: I have a spare Epson sx445w printer, can I use this to print T-shirt transfers, if so what type of ink do I need to change the printer to.
2: what paper do I need to print designs to cotton t-shirts.
Thanks in advance
Carl
Sent from my A0001 using Tapatalk
jonna
Post by jonna »
Is the spare printer one you have previously used? using 2 different inks form 2 different manufacturers may alter the quality use either pigment or dye based inks for your transfers printing onto a good quality transfer paper. There are many suppliers and as you are also a premium member you will get a discount. There are 2 types one for light coloured garments and one for dark.
abacus1983
Cheers for the info, yes the printer was used with the standard Epson inks that came with it at the time, would it he best to invest in another printer instead
Best regards
jonna
Post by jonna »
it should be fine to use for transfers, after all most transfer papers are capable of using dye based or pigment which most inkjet printers use
