sunangel
Hayling framing
Re: sunangel
Post by Hayling framing »
hi all is anyone using the sunangel colour/white laser printers???
ArferMo
Re: sunangel
Post by ArferMo »
yes there are a few of us on here
Hayling framing
Re: sunangel
ok thats great so how are you doing with it? ease of use? results? i know the paper is fairly costly
ArferMo
Re: sunangel
Post by ArferMo »
The paper pair make prints very costly, there is a learning curve with how to do your designs so that you avoid registration issues and you need very tight temperature control. You must be quick when you open the press to separate the A and B or it will cost you a couple of quid for being too slow and letting them cool too much.
Once you get the hang of all that it's a very easy system to use.
omar78
Re: sunangel
Post by omar78 »
I've not managed to get the hang of it.. on the registration side .. so maybe selling the White toner printer.
ArferMo
Re: sunangel
Post by ArferMo »
I'd need to see a design to be able to advise.
Don't give up too soon, many people just do white designs with the white printer.
omar78
Re: sunangel
Post by omar78 »
I will post a photo later. It doesn't help that I have a different model of OKI colour printer (C841)
ArferMo
Re: sunangel
Post by ArferMo »
The model number does not matter much with the alignment issue as long as the toner type is compatible with the transfer papers. OKI use lots of different toners in different printers and some WON'T work. I have 8 OKI printers here 4 different models BUT all use the same toner which is the one that is compatible with sunAngel and WoW and forever papers.
omar78
Re: sunangel
Post by omar78 »
I don't have any issues with image quality.. just the alignment..
vB_ID:3755
vB_ID:3755
Photo 23-11-2015 17 46 46.jpg (95.96 KiB) Viewed 626 times
ArferMo
Re: sunangel
Post by ArferMo »
been out all afternoon just back.
so is it out of alignment left to right or top to bottom can't tell which way you printed that from that little bit of the image.
