epson 1500w
Re: epson 1500w
anyone with this printers give us an update why it doing this
it keeps sending the 1st paper straight through he machine, then saying paper out or incorrect loading...
getting more n often now...:rolleyes:
have fanned the sub papers before putting them in....
something i,m missing setting wise ?
or is it just not picking the 1st one up for what ever reason...
gets the next one ok
Re: epson 1500w
I use the 1500w all the time and not had that problem! Could be the paper itself! Is it sub paper or ordinary paper?
Re: epson 1500w
sub papers jamesJames990;108535 wrote:I use the 1500w all the time and not had that problem! Could be the paper itself! Is it sub paper or ordinary paper?
off to try some trupix stuff n see if still same
Re: epson 1500w
Ah, that could be the problem, Trupix though should be alright. Some of the other papers can cause problems. It did when I was using a Photo 220, but ordinary paper doesn't!
Re: epson 1500w
doing the same with them.....and loading some of them offset with the trupix....
is there a setting in the software or something ?
the papers are sitting correct in the paper feed, both brackets snug fit to paper either side
Re: epson 1500w
man is this epson temperamental..(bit like my ex tbh)..phew, glad she gone..sorry, back on topic......
compared to the other espons we had over the yrs....
got it fixed....
our 1500 is on a raised part of one of the work desks....and the paper holder at the top was NOT fully extended backwards, it was more upright due to space...mainly the wall behind it
fixed that then....
because we pulled it out from the wall a tad, the front of printer came off the shelve, we put wee bit o cardboard to balance it out.....hell no...it was not liking that.
was jamming with the corners of the paper jamming on the print head...
took some farting about with bits o cardboard to get it just right...but got it
loading and printing perfect....
our other epsons didnt bother if the front end was slightly tipped down...but hey ho, if every new printer was the same, this job would be boring as hell LMAO
worthy note in case anyone else has this same problem
got it fixed....
fixed that then....
Re: epson 1500w
dam problem is back again...
epson 1500w is sending the paper straight through again, with - paper out or incorrect loading
this is starting to tick one off just a tad
note to one self....
must restrain me from using hammer...i must.....means need to buy another one.....must .....must....coffee time, not hammer time !
Re: epson 1500w
Speak nicely to your 1500w and it will be fine, NO do not pour that coffee over it, waste of coffee. If you need a new hammer, I have one!!!!!
phoenixalpha
Re: epson 1500w
I have on occasion used different sub papers in my Epson and after the first half a dozen sheets feeding fine, it misfed and just kept pulling paper through, sheet after sheet - incorrect loading or paper out. Filling the tray with Trupix first couple of attempts proved unsuccessful then back to normal - perfect every time. I would guess that some other paper types have a coating on them which comes off onto the Epson rollers or sensors and causes merry hell. Have always stuck with Trupix apart from when I cant get it and then its just a nightmare.
Re: epson 1500w
using trupix now....and they are fine 99% of time.
was using the dino papers and we really liked the depth or colours we got from it...
but if this is what we have to go through every day, to hell with using dino papers on main printer.
will keep them for the other stuff
