Dunking Mugs - It works!!
RogerC
Re: Dunking Mugs - It works!!
Post by RogerC »
KathG;112573 wrote:Do you dunk in hot or cold water.....I really hate the noise the mug makes if I dunk. :)
Warm to start with and as you dunk more and more it gets hotter but still has the desired effect of cooling from sublimation temperature and averting 'ouch ouch' fingers.
ukuwi
Post by ukuwi »
I take straight from the press with paper still intact and run the hot water first into the mug then with cold water a little slower to avoid a drastic change in temperature , I don't do many mugs but so far not had any problems .
We shall certainly try paper on when dunking next time to save those burnt fingers!
