Hi, can someone help please, my daughter has just bought the printer with sublimation inks, she is using corel draw 6, I know ICC profile has to be installed, but there are no instructions on how to install the ICC profile and no instructions on how to set it up in corel draw 6, can someone help please run me through the set up, the printer is installed, it's all working, just need to set the ICC profile for the printer and in corel draw 6, is there a video I can watch?
Trev
Ricoh Aficio SG 2100n sublimation
bigbadtrev
Re: Ricoh Aficio SG 2100n sublimation
This may be not what you want to hear but me personally would be brave, ditch the whole lot and buy a set up from a recognized supplier with full support. There are many posts on here, have a quick search, about the 2100 not being suitable for sublimation. If it is not a Gel ink that these printers require then you will not get very far.
I know some people have had some success but I think the general consensus is they are more trouble than they are worth.
I believe that most ICC profiles need to be set up according to what paper, substrates and ink you going to use. If you ever change one of these you will require a new ICC profile.
A fully supported start up deal from a main supplier will give you all of this with the Sawgrass Powerdriver.
I wish I could be of more help.:frown:
You could start with the link below which is for an older printer model (but one that was supported) or just Google 'Install ICC profile CorelDraw'.bigbadtrev;114846 wrote:Hi, can someone help please, my daughter has just bought the printer with sublimation inks, she is using corel draw 6, I know ICC profile has to be installed, but there are no instructions on how to install the ICC profile and no instructions on how to set it up in corel draw 6, can someone help please run me through the set up, the printer is installed, it's all working, just need to set the ICC profile for the printer and in corel draw 6, is there a video I can watch?
Trev
http://sawgrassink.indigofiles.com/prod ... ctions.pdf
mags1892
It will work fine I will make you a profile and help you install it I have many clients using that machine no problems at all. If you have a profile ill send you a document to show you where to install it and how to setup corel.
bigbadtrev
Thank you that would be great, we are using corel draw 6 64bitmags1892;114878 wrote:It will work fine I will make you a profile and help you install it I have many clients using that machine no problems at all. If you have a profile ill send you a document to show you where to install it and how to setup corel.
Trevor
