cap press for doing sleeves
Re: cap press for doing sleeves
Look at the soft heating ellement. Is same as on swing away. Its also smaller with bad shape. This is what makes those press so bad. Galaxy looks and works alright and you can change bases.
i paid less as i took advantage of ebay offer. so it saved me £50.
Hi Paul , do you know much about colour profiles , have just bought ricoh sg3110dn and have installed generic c eye sub inks and installed driver but the images are very low contrast and faint can you recommend a link for icc profile for this set up , thanks Robert
yeah, I did heard one or two things about icc's...greenman1;111309 wrote:Hi Paul , do you know much about colour profiles , have just bought ricoh sg3110dn and have installed generic c eye sub inks and installed driver but the images are very low contrast and faint can you recommend a link for icc profile for this set up , thanks Robert
sis you installed corect cartridges in to your printer? are you sure your ink is sublimation ink? I take it it sawgrass ink?
Hi Paul the inks are sublimation inks but not sawgrass they are c-eye inks I thought when i bought them they would maybe slightly inferior too sawgrass but the colours and contrast are way off , the cartridges are gc41 supposedly compatible with ricoh sg 3110dn printer ...
forgot to update on this thread, got myself a Galaxy Pluto press, ploughed through 130 shirts, very pleased with it indeed so it has alreay paid for itself.
Just need to get myself a pluto 38x38 now!
Sublime Print
HI Paul, How's the cap press so far? I have the Galaxy 15x15 auto open press and looking for a cap press
Danny
Danny
Earl Smith
I bought a cap press many years ago when I worked in Spain. The shape is wrong for most caps so I lay an old t-shirt on the plattern to compensate for the bad shape.
I use it for caps , t-shirts, Bags and anything that is not able to go into the larger press because there is a Zip in the way.
A very usefull press to have.
Danny,
The galaxy pluto is a good bit of kit to have, i do mostly sleeves but will be doing caps also soon, well worth the money and a very solid piece of equipment with different size platens available, i just got the standard with mine but I think they run in at around £40.00 to £45.00 for bigger ones.
