Laminated photo blocks, acrylics etc.
froggy
Has thanked: 1 time
Been thanked: 2 times
Re: Laminated photo blocks, acrylics etc.
Post by froggy »
Justin;119650 wrote:I've been putting the laminate onto the block first but think I need to laminate the photo and then apply, either way I think I'll need a laminator.
I think so, I dont think they are silly dear, its something I looked at a couple of years ago, but things happened and I went in a different direction. They are a beautiful premium product when done correctly. Laminator wise I would go as big as my printer could produce.
£390 delivered, 25" cold electric, 25mm opening.
froggy
Has thanked: 1 time
Post by froggy »
Justin;119657 wrote:£390 delivered, 25" cold electric, 25mm opening.
Doesn't sound much for a product range with the potential earnings these have. Some lovely ways of displaying them on a wall too.
Good luck.
Woolers1
Post by Woolers1 »
Justin, are you still looking for a set up or are you sorted interested in a sample of our pressure sensisitive laminate. We also cut acrylic sheets to order but10mm maximum thickness.
Still playing with this, need a thinner photo paper and have to get the laminator.
I need 20mm acrylics for this. Always worth looking at other laminate! Do you sell this?
Woolers1
Post by Woolers1 »
Have you not tried polypropylene paper you will get fantastic results with it, most photo papers have a texture and leave silvering. Yes we sell all you would need polypropylene paper, laminate, and 15mm and 20mm blocks. Let me know if you would like a sample.
Fire me a PM over with your company details.
whitprints
Post by whitprints »
polypropylene works well for these
DyeSubSupplies
Post by DyeSubSupplies »
The paper below works very well with Acrylics
http://www.canvasandstretcherbars.co.uk ... ner-Paper/
whitprints;124863 wrote:polypropylene works well for these
Wooers1, you seem to know a bit about acryllic...
I am looking for a .5mm Heat Resistant acryllic that I can direct print on to. Ideally would like something that I can cut easily either with scissors or a cheap laser cutter.
Any ideas?
