Little Ghost White Toner Bundle
cyprian.costelloe
Re: Little Ghost White Toner Bundle
Post by cyprian.costelloe »
I did, I did however notice that there was a bit of static causing the film to stick to the paper. On the last print I took all the paper out and put the sheet in on its own.
Sent from my HTC One_M8 using Tapatalk
cyprian.costelloe
The paper didn't really curl, did you change the paper setting to "transparency"
Umm, perhaps we didn't.
cyprian.costelloe
That is the only thing I changed apart from the monochrome seeing when I printed the white.
cyprian.costelloe
"Setting" hate auto-correct. :)
We've finally managed to print something with ours bought at Spring Fair!
(A red mug bought at Wilkos!)
First frustration was after waiting for the mug to cool after pressing, the transfer was still stuck to the mug, so my wife took it into the kitchen and had to wash it off, before we could then repress to cure the transfer on - not looking an efficient work flow so far.
The white was a little translucent, so more pink than white.
The mug has been through the dishwasher a few times since, and has survived.
cyprian.costelloe
Haven't tried this but been told that with the hard surface transfer, after pressing let it cool for two mins then put in water for two mins, peel off slow and steady. I only have the papers for material at the moment so can't confirm if this works.
vibcol
Post by vibcol »
How does this compare to something like the TMT Okis?
It doesn't, the TMT papers are considerably better as is the whole TMT system. However there is quite a difference in the prices, so you pays your money and takes your choice :-)
MRSTONE
Post by MRSTONE »
Hi, Im yet to master the dark transfer process. just to confirm you print colour image. Then you go back to image editor and print the same image in white?
