Colours faded
warlycarly
Re: Colours faded
Hello, I have just bought a 3d heat press - ST2042. I am using the same paper, ink and mugs as I used in my old mug press, all worked fine. But in this heat press the colour is really faded. I used the recommended settings 200c for 6 mins for 1 mug, and 195c for 6 minutes for 1 plate, and I got the same results with both. It's as if the ink hasn't fully transferred... Can anyone tell me what I might be doing wrong. I know paper, ink and mugs are fine as I've been using them for a couple of years and they have been perfect.. Thanks in advance.
Re: Colours faded
I don't own a vacuum press, but I believe you have to press the heat switch TWICE to turn on both top and bottom heating elements.
Maybe someone with more knowledge will be along soon though.
warlycarly
Re: Colours faded
Thanks for replying. It turns out the vacuum wasn't working properly for the plates, so that's now fixed, and I set the time for longer, its all good now. So if anyone else has this problem, my settings are plates: 200c for 8 mins, and mugs 200c for 8.5 mins.webtrekker;124288 wrote:I don't own a vacuum press, but I believe you have to press the heat switch TWICE to turn on both top and bottom heating elements.
