soft shell jackets, etc... might be a strange question!!
TQfan
Re: soft shell jackets, etc... might be a strange question!!
Post by TQfan »
Hi
I've been doing a club logo on the left chest area on t-shirts, polos, jumpers, and hoodies for a client. They are now interested in jackets - the soft shell type being one, bomber jacket another.
They have asked a question - does embroidery make the jacket no longer waterproof?? i'm guessing because of the needle holes.
anyone have any information on this? :confused:
thanks :biggrin:
logobear
Post by logobear »
you can get an iron on waterproof backing for the embroidery to re-proof it
pw66
Post by pw66 »
Three ply softshell has a middle layer of waterproof laminate, so you will need a waterproof backing. Cheaper 2 ply doesn't have the waterproof laminate, so although it will make the garment less waterproof it doesn't really matter because it was only 'showerproof' in the first place.
You can also heatpress onto softshell, but you must use a blockout vinyl to avoid dye migration. Try to keep the temperature below 175c - any higher and you risk the waterproof membrane delaminating. You can sublimate onto lighter colours, but the temperature issue will probably limit you to 2 ply jackets, without the waterproof membrane.
TQfan
Post by TQfan »
logobear;129718 wrote:you can get an iron on waterproof backing for the embroidery to re-proof it
do you have a brand? or name?
TQfan
Post by TQfan »
pw66;129721 wrote:Three ply softshell has a middle layer of waterproof laminate, so you will need a waterproof backing. Cheaper 2 ply doesn't have the waterproof laminate, so although it will make the garment less waterproof it doesn't really matter because it was only 'showerproof' in the first place.
thank you for the info, i'll need to check what ply the jackets are. i did think it might be a bit pointless if the jacket was only shower proof... the jackets have a concealed pouch for embroidery, so i don't think water would get through to the skin anyway!!
as for vinyl, it wasn't something i'd thought about but certainly will now. we have embroidered one colour logos of this design so vinyl is something to think about as well. thanks
pw66
Post by pw66 »
I regularly press onto Result, Uneek and Russell softshell using mdp 'blockout' (160c) with no problems of dye migration or delamination. I made the mistake once of using ordinay white hotflex, and the migration was the worse I have ever seen. It took a day or two to start, but kept getting worse for weeks - it looked like the white flex had gone mildew.
Be careful of the temperature if using a heat applied waterproof backing. I don't know how susceptable to dye migration embroidery thread is, but it could potentialy be a problem.
Have you printed jackets before? If not, one thing to remember ( learnt the hard way!) is that the plastic zips can melt if exposed to the heat press. Use pads or pillows if needed.
TQfan
Post by TQfan »
pw66;129735 wrote:I regularly press onto Result, Uneek and Russell softshell using mdp 'blockout' (160c) with no problems of dye migration or delamination. I made the mistake once of using ordinay white hotflex, and the migration was the worse I have ever seen. It took a day or two to start, but kept getting worse for weeks - it looked like the white flex had gone mildew.
Spoke to the client and they'll definitely be wanting embroidery. So now i will check into the thread.
Haven't done jackets before, but have done some gym sacs and had already read about using a pad/pillow to avoid burning the handles on those, but not sure if i'd have thought about the zips, so thank you! always seems like there is so much to learn!!
i can't remember the brands of the jackets off hand, i think i gave them a choice of about 10 different ones. but i did check the quality after you mentioned it, and there is a mixture of 2 ply and 3 ply, so it will all depend now on which jacket they plump for!
thanks!
Europa&Ganymede
Post by Europa&Ganymede »
TQfan;129730 wrote:do you have a brand? or name?
Pretty sure Madeira do one. We've used it on kit bags before but we've had the roll so long I can't be 100% if it's theirs.
TQfan
Post by TQfan »
Europa&Ganymede;129792 wrote:Pretty sure Madeira do one. We've used it on kit bags before but we've had the roll so long I can't be 100% if it's theirs.
i have had to create an account with them as can't seem to find it anywhere else. thank you so much :biggrin:
