New blanket/wrap not working
MissyH
Re: New blanket/wrap not working
Post by MissyH »
I have bought a new mug wrap/blanket for my machine but after putting it together the temp display is showing 000 and not getting hot!
Can some one tell me what I have done wrong?
propobly nothing! you simply got faulty spare blanket. return it and ask for replacment.
MissyH
Post by MissyH »
I dont think its that, I am sure I remember reading somewhere that it was a wiring issue but I cant remember where or when I saw it. I got it from BMS so if it turns out to be an issue with the blanket then I am sure they would replace it but if I can get it fixed then all the better as I really need to get it sorted today.
Ian M
Post by Ian M »
Hi Paula,
Why not give Martin at BMS a call as he always very helpful.
Ian :D
yep ;)
Give MArtin a shout. I am sure if your blanket is faulty he can get you replacment in24h ;)
As I understand it the blanket has been bought as a replacement for the DF1 mug press, but you don't have a DF1 mug press. There is no guarantee a blanket for one mug press will work in a different mug press. You would need to get an electrician to look at the wiring inside your mug press and see how this links to the wiring in the mug blanket we have provided.
