Progress with Epson Surecolor SC-P600-
In our last post we had produced the colour swatch charts for the profile to be made for the SC-P600 using the Inktec Sublinova Smart ink set. The ICC was finalised over the weekend so we set about testing the printer and producing some initial test prints.
Comparisons-
We produced a test print image to test full colour, BW and gradient colours. We printed the image on our Subli-Sharp transfer paper. We produced two test images one printed using the ICC profile and the other with the printer managing the colour.
Below shows the two prints; print at the top is with printer managing colour and print at the bottom is using the ICC profile-
- vB_ID:5219
- IMG_0515.jpg (89.63 KiB) Viewed 596 times
Close up showing a great improvement with reds, the print at the top is with the ICC profile, the print at the bottom is with the printer managing the colour-
- vB_ID:5219
Again improvement on red; print with ICC on the left, print without on the right-
- vB_ID:5219
Black and white areas are also improved; print on right is without ICC profile and greys have a magenta hue / cast. The print on the left is printed using the ICC and has improved neutral tone in the black and white areas-
- vB_ID:5219
With the test images produced on the paper we then heat pressed on to sublimation coated aluminium sheets, we followed their press instructions and pressed at 200c for 120 seconds. The images below show the two images following heat pressing.
The sheet at the top is without the ICC profile the sheet at the bottom is with the ICC profile; as expected the pressed sheet from the print with the ICC had greatly improved red, brighter yellow, blues and greens-
- vB_ID:5219
Close up showing improved red following heat transfer, sheet on the left is without ICC, sheet on the left is with ICC-
- vB_ID:5219
Close up showing overall improvement on and brighter colours on blue, green and yellow as well as improved skin tones-
- vB_ID:5219
Overall photo showing the aluminium sheet produced using the ICC print-
- vB_ID:5219
Comparing with the Epson 1500W-
We decided to test the SC-P600 against the 1500W, we found the results were almost identical. Which in a way is a little disappointing, but in hindsight this goes to demonstrate how good the 1500W printer was. The SC-P600 produces extremely similar colours over the color spectrum.
We used a test image comprised of well known blue chip company brand logos as everyone knows how these should look in terms of colour so it is always a good demonstration of the colour matching a printer can produce.
The test images were heat pressed on to the aluminium sheets and placed side by side. There is very very little difference between the two. The SC-P600 has a very slight improvement in the red on the Argos logo and the grey in the Kobo and LG logos is more neutral than the print from the 1500W. So overall very slight improvments but goes to show the SC-P600 is certainly a viable alternative printer.
- vB_ID:5219
Media testing-
The last thing to test with the SC-P600 was the media handling. As we all know there are hundreds of different types of sublimation papers and with the introduction of 3D film we have heard from lots of customers who expereince issues with their media as a result of their printers.
3D film - its very common for this to misfeed in a printer but the biggest issue is the paper rollers scoring / scratching or marking the media as it prints. Justin knows this all too well and was always pleased with the 1500W as it did not mark his particular media. Justin kindly supplied me with some sample sheets of his 3D film to test.
I am pleased to say that the SC-P600 fed the film without issue, both single sheet and when stacked (around 10-15 sheets) and produced multiple prints back to back. Also there were no marks at all on the print following printing which is excellent.
Print on 3D film showing no marks or scratches-
- vB_ID:5219
High release sublimation paper - High release or HR sublimation paper can also be an issue for printers and the soft coating often gets marked by the paper feed rollers (known as pizza cutter marks) We supply a HR paper called Subli-TEXTILE it has a very similar coating to TEXprint XPHR paper and we are aware of the coating being scratched or marked by printers.
Again we are pleased to say that the SC-P600 printed on both our Subli-TEXTILE and TEXprint XPHR papers without marking the media or coating.
Print on Subli-TEXTILE HR paper showing no marks-
- vB_ID:5219
Further tests-
We will be completing some further tests with the SC-P600 printing on to various substrates (*ceramic, polyester, canvas, polyester silk etc) to test it on all possible variations that people may want to use. Hopefully all being well we will be offering it for sale in the coming weeks.
Alex
