Mug press for sale. Touch screen bnib.
Re: Mug press for sale. Touch screen bnib.
Brand new. Great quality press. You can calibrate heat.
£100 delivered if paid paypal as friend.
- vB_ID:5331
- FCC46C97-6F47-4472-95B3-9EFD2FA59EBB.jpg (38.17 KiB) Viewed 662 times
- vB_ID:5330
- E2EB230C-B12B-413B-8D2F-CFAFA04365F3.jpg (47.15 KiB) Viewed 662 times
Hi, what brand is this product?
Also is it auto or manual and have yoy got a picture of the actual item?
Sent from my SM-G950F using Tapatalk
its made by freesub. and what do you mean by auto or manual?
it does start countdown automatically after closing press if this is what you mean?
Okay that's fine.
I'm literally looking into purchasing a sublimation printer along with a hot press.
And a mug presser was the next thing i'm looking into.
Will defo be in touch in the coming days.
Ash
Ash
Sent from my SM-G950F using TapatalkPaul;132992 wrote:its made by freesub. and what do you mean by auto or manual?
[MENTION=4]Paul[/MENTION] - Does it heat the mug before it starts counting down or does it start counting down right away?
you can set it to heat to the temperature of your choice before countdown will start.
Sorry Paul, what I meant was, most modern presses have an idle temperature, then when you put a mug in, it detects the temperature of the mug and then heats the mug up. Once the mug is heated to the set temperature, the timer starts to count down.Paul;133117 wrote:you can set it to heat to the temperature of your choice before countdown will start.
Is is that how this works or does it start counting down as soon as the press is activated?
yeah, it has idle temp.gazfocus;133118 wrote:Sorry Paul, what I meant was, most modern presses have an idle temperature, then when you put a mug in, it detects the temperature of the mug and then heats the mug up. Once the mug is heated to the set temperature, the timer starts to count down.
That’s not what I asked. I know I’m not always the best at explaining things but even I don’t think what I’m asking is that hard to understand.Paul;133124 wrote:yeah, it has idle temp.
Nevermond, I’ll leave it.
This might help answer some of the questions:
https://freesub.en.made-in-china.com/pr ... -130-.html
Or Aliexpress:
https://www.aliexpress.com/item/New-Arr ... 21620.html
Or Aliexpress:
